NI 9205
Hello I'm new with cDAQ and I have a question with module NI 9205.
I want to adquire 5 signals from a LEM and 2 voltage signals from another device.
Attached schematic and datasheet.
Is my configuration okey?
thanks
Message 1 of 8
(1,694 Views)
Hi rufus,
I don't see any GND/COM connection in your schematics…
And I hope you don't want to (ab)use the 9205 to supply power to your LEM sensors!
Message 2 of 8
(1,688 Views)
And how should I connect it?
thanks
Message 3 of 8
(1,683 Views)
Hi rufus,
As shown in the datasheet of your HAX850 sensors!
To measure a voltage you need to connect OUTPUT and GND pins to your 9205.
Those sensors need a ±15V power supply…
To discuss such questions you should supply a real electrical schematic, showing all relevant devices (power supply, sensor(s), DAQ) and all the needed connections!
Message 4 of 8
(1,675 Views)
Yes I know the 15V power supply for the LEM.
The pin 3 of the LEM (Output) to AI0 of 9205.
The pin 4 of the LEM (0V) to AI8 of 9205.
The connection with 9205 is it okey?
Message 5 of 8
(1,663 Views)
Hi rufus,
So all connections labeled with a minus in the name refer to a GND connection?
What about those "V1±/V2±" connections to your 9205? Do you want to measure the voltage supply too?
The 9205 can only measure ±10V, so ±15V is "out of range"…
Message 6 of 8
(1,644 Views)
Yes pin4 of the LEM.
No, I want to measure the voltage of the equipment that I want to test. For that I´m going to make a voltage divider.
Message 7 of 8
(1,640 Views)
Hi rufus,
well, now it looks like a viable solution.
You should learn from this thread: when discussing questions about electrical schematics you should always supply a good electrical schematic! (There are even free web-based tools to create such schematics.)
Message 8 of 8
(1,624 Views)
