This widget could not be displayed.
NI 9214 on cRIO 9014
Could you please tell me your solution about this issue? Thanks very much.
Message 11 of 14
(840 Views)
Hi Kyle,
did you read the message just before your question?
The solution was to install the RealTime module to be able to get access to a RealTime target…
Message 12 of 14
(836 Views)
Hi Gerd
Actually I have installed Real time module,and can find Crio in MAX. However in Project I can only see the Chassis, all C series are missing. And if I want to change the properties of the Target, it will show 'unexpected error occurred '.
Did you meet this issue before?
Thank you & BR
Kyle
Message 13 of 14
(815 Views)
Hello all,
I am experiencing this exact issue. I installed FPGA and RT modules as wells as the CompactRIO driver 18.5, which is recommended for LabVIEW 2018SP1 (the version I use). I see there was no answer to this last message.
Does anyone know?
Thanks for the help.
Message 14 of 14
(666 Views)
