NI-9215 for two labview programs
I would like to know if I can use the same NI-9215 for two different labview programs. Because just one input is being used at the moment, so I have some inputs avaliable to use. Can I use these inputs with other labwiew program?
P.s.: I have already the labview programs done. So would be easier just to conect them in both programs.
I appreciate any help.
(2,415 Views)
You can't run both programs at the same time.
But if you run them individually, then yes you can do that.
(2,407 Views)
