NI 9215 sampling frequency not achieved
I am working with an analog input module NI 9215 on CRIO 9039, using a 40 MHz FPGA base clock. I need to synchronously sample on all the 4 available input channels at 40 kS/s (that is, 1000 ticks for each acquisition period) , which is far below the maximum declared rate (100 kS/s synchronously on each channel); nevertheless, it seems not to be achievable in practice.
I attach a very simple scheme that, if compiled and run from FPGA VI, can only achieve 1068 ticks for acquisition period instead of 1000 required by my application. I also tried similar schemes, but with no success.
Does enybody else get the same result? Could somebody explain me where is the problem?
Thank you!
(2,968 Views)
Accepted by topic author prova123
4 loop timers in one loop makes no sense. Just use one flat sequence structure with ONE loop timer, and instead of using 4 fpga IO nodes use just one- you can expand or grow the node and read all 4 channels from one node. See where that goes
(2,934 Views)
