NI 9219 TC Mode
Hi folks,
i want to use the NI 9219 module to measure my temperature with thermocouples.
I had a look at the example. There you have to select the channel CJC. This is needed to transform
the signal in a temperature.
It´s all clear, but the CJC channel is not offered in my case!?
I can´t create it..
Is there a special way to create it?
Mod 4 is my 9219
Thanks for your help
(3,259 Views)
Hello Stirl,
Thank you for your post. You have to change the mode from the 9219. Please select the module, right click for properties. Here you will be able to change each channel mode from voltage to thermocouple. The CJC I/O will be added in the project.
I hope this helps, best regards,
Martijn
Martijn S
NI Netherlands
(3,246 Views)
Hi Martijn,
that helps a lot. Thanks, that saved me a lot of time.
I knew it must be very simple, but i coulnd´t find out.
Cheers
  Andi
(3,237 Views)
