NI-9234 streams sometimes valid data, sometimes 0
I have a simple application to readout data from NI-9234 modules, and display the values in indicators:
When I run this (on cRIO FPGA, under LabView), sometimes only 0 are readout and readout is a bit slow:
When stopped and run again, sometimes valid data appear:
I also noted that when data are updated and non-zero, the counter (Numeric indicator on the front panel) increases much faster.
I come to this as I am reading 0 in a more complex application, which stores data into FIFO. Any hint of what might be wrong? Why it sometimes works and sometimes doesn't - all I do to make it run is to stop the application and start it again.
(1,043 Views)
Accepted by topic author lsstpkubanek
The problem is most likely solved. The behavior was triggered by syncy=ing NI-9234 to the clock provided by NI-9469 time synchronization module. When synced to NI-9234 clocks, non-zero data are readout all the time as expected.
(1,021 Views)
