NI 9237 Null Range
What is the range that the 9237 card can balance out using the bridge offset null calibration? I am writing a program that will be collecting four load cells with the 9237 card so I will be using 2.5V of excitation. Playing with my program with only one load cell connected I can use the bridge offset null to balance the bridge and it works fine with 10V excitation . When I put the excitation down to 2.5 Volts, I get an error -201398. With 2.5 Vex the offset value would be closer to zero, so I don't understand why it is having trouble trying to balance the bridge.
(3,086 Views)
adekruif,
This issue pertains more to our DAQ Bridge Input hardware rather than LabVIEW itself. Please repost this thread in the appropriate forum board and we'll gladly try to help out.
Patrick O.
Applications Engineering
(3,033 Views)
