NI 9237 continuous sampling loop reading rate
NI 9237 continious sampling
sampling rate:2k
Have a while loop to read the samples.
N channel N sample 1D waveform
1, If I set a number of samples to read, no mater what the number is (i.e. 10, 20, 50, 100), the loop reading rate is like only 5Hz (read 5 times oer second)
2, if I don't set a number of samples to read (i.e. read all available samples), the loop reading rate is as fast as it can be, but the Y attribution of the waveform cannot be get ( i.e. empty array), the waveform can be shown on the chart control though.
(2,648 Views)
Hi Eric_LZ,
I noticed that you posted this inquiry twice. In order to consolidate the answers that you will be getting, I think it is better if we answer the questions here.
Best,
Jason M.
(2,625 Views)
