NI 9237 sampling rate problem
I am using NI 9237 datalogger and labview signal express 3.0. I measured strain using full bridge configuration. the data recorded was for strain corresponding to every 0.00062 second and i am getting a huge data. I want to measure strain data for one second, i changed sampling rate but it was of no use. Could anyone tell me how to change sampling rate to 1Hz in NI 9237.
(2,772 Views)
Hello Raj13,
Since you are using SignalExpress, I would suggest you post your questions in that forum, located here:
SignalExpress Forum
http://forums.ni.com/t5/SignalExpress/bd-p/380
That being said, the 9237 Manual clearly states that the module has a minimum sampling rate of 391 S/sec (using an external timebase, ~1.6 kS/sec default), which means you won't be able to configure it to acquire at 1 Hz.  You'll likely need to average multiple samples.
Tom L.
(2,743 Views)
Thanks a lot
(2,724 Views)
