NI 9239, can a /-10V data acquisition card be used to measure 0-20V signal?
Hello everyone,
                 I have NI9239 daq card, which has input range of +/-10V. Is it possible to measure 0-20V signal on same daq? if yes what would be the best approach?
Thanks!
Kudos are (always) welcome for the good post. 🙂
(2,706 Views)
You'd need to level-shift your 20V signal down 10 Volts. Then you can compensate for it in software.
(2,700 Views)
