NI 9263 remains at constant voltage after Labview exits
Hi all,
I have a problem that when I write a waveform to my NI 9236 on a cDAQ 9174 it remains at a constant voltage after the Labview program finishes until I unplog the USB cable.  I would like it to go back to zero, so that I can leave it running by itself and not worry about burning the resistor for hours after the program finishes.  I tried putting a DAQmx Clear Task at the end of the program, but that doesn't seem to help.  Any ideas?
Matt
(2,609 Views)
reset the device after clearing the task
(2,608 Views)
This is a basic question that has been asked and answered numerous times. If you want the device to output a certain value, you need to program it to output that certain value. Add a DAQ Assistant or a simple DAQmx Write as the last thing your program does.
(2,595 Views)
