NI 9263 taking too long to write arb waveform
Hi, I've been trying to simulate a QRS waveform for a simulation program I am making.  I have the waveform plotted, I can get the timing right, and scale it. I am using a Ni 9263 DAQ. When I first start the program I write the waveform to the DAQ and right away on my osciliscope I see the waveform. Now I have set a timer to delay a certain amount of time (usually about 20-60 seconds). When I get to the next for loop (I have to change the waveforms amplitude to 3 different settings) it takes about 10 seconds for the waveform to change.
 At first I was thinking it could be a limit of the write speed of the DAQ, but I limited the number of points (about 500 over 2 seconds, should be able to do it no problem) and it still takes the same amount of time. I also do not think this is the problem because as soon as I enter the loop the first time it just goes right away.  Am I doing something wrong here, do I need to clear the data first?
(2,619 Views)
Hi Scotty V,
It's unclear to me from the snapshot how your program really works especially that it looks like you created the task in MAX.
I would really apreciate if you can attach the real VI you are using.
However, it's worth saying that you can not run more than one task in DAQmx . I'm guessing here that when you are asking the device to run the new task, the delay loop has not finished yet.
Faris
Bueller
(2,586 Views)
Yeah, I rewrote the program, i start and stop the task at each command now and it works fine. Thanks.
(2,579 Views)
