NI 9263
I need an analog voltage siganl to control a pressure regulator, the regulator requires a current between 4-20mA to run and the module I have 9263 only outputs 1mA of current per channel. Any solutions to my problem?
Jonny
(3,059 Views)
You could add higher current opamps to the 9263 outputs as buffers.  Or maybe you could instead use the 9265.  But in general, it doesn't look like the 9263 on its own fits your application.
(3,055 Views)
