NI 9269 + cRio: sine generation
Hi folks.
I want to generate a sine with variable frequency and amplitude.
I am working with a cRio 9033, a tension output module NI 9269 and labview 14 in Scan Interface mode, therefore I can not use the DAQ Assistant .
I tried to use the Simulate Signal, but after 5 Hz and any amplitude the output signal is not correct.
Does anyone can show me how to do it? Thanks
(3,275 Views)
You should use the Sine Waveform.VI to generate the sine wave and later move every single point to the output channel in every iteration, for instance, of a timed loop.
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/analysis/1siggen-llb/sine-wave-vi.h...
https://forums.ni.com/t5/Real-Time-Measurement-and/Outputting-waveform-using-NI-9269-on-cRIO-9114/td...
Have a nice day.
(3,250 Views)
