NI 9401 Multiple Digital Outputs
Hello, LabVIEW community, I'm using NI 9401 for digital output on cDAQ-9178. I'm using line 6 to send a 160Hz clock signal to the MUX and line 5 to toggle control the MUX reset terminal (function as power control). Toggle ON, the MUX is running at a specific frequency, toggle OFF, it stops. When I try to put it together, it does not work. Any suggestion or modifications would be greatly appreciated. Thanks.
(2,272 Views)
Solved
(2,259 Views)
