NI 9401 for measuring flow rate
Hello everybody
I am here looking for a help. I am a beginner through LabView and DAQ equipment.
I have a NI 9401 and a flow meter, they are already wired, and it's already counting the edges.
I have the number of pulses/liter, but I need to get the number of edges that were counted per second as well for each loop, like a frequency, to make the conversion through the equation.
I do not know if I am doing this in the better manner, so I accept suggestions.
Thank you all in advance
Greetings from Germany
(514 Views)
Accepted by topic author ViniCampos
Hi (und hallo) Vini,
  • Let the loop iterate once per second.
  • Keep the last counter value in a shift register.
  • Calculate the difference of current and last counter value to get the number of pulses for the last second.
  • Do your conversion to get the flow rate…
(511 Views)
Thank you...
It worked perfectly.
(438 Views)
