NI 9411 for Serial Data
hypfco wrote:
Because i would use the data transmission between a large distance (more than 100m), i think the PCB interface will be required in any case.
With those distances, you should be using Ethernet, not serial/TTL signals.  And Ethernet requires 0 slots.  You might need a network switch.
GCentral
Message 11 of 11
(466 Views)
