NI 9467 and DSA modules
Hi all,
I am working with cRIO 9063 with 9239 card for acquisition and 9467 GPS module. I am trying to sync the acquisition to be on each PPS from the GPS but no sucess. It seems that the internal clock of the 9239 is not allowing me to do that. The examples that I saw are for SAR modules that do not have an internal clock. I need this so I can sync multiple crio distributed on vast area.
Timekeeper VI's are used to sync the FPGA clock with GPS time.
Any ideas? Thanks
(3,001 Views)
Hi TinoMK,
I am not very familiar with GPS, but I found this forum that might help:
https://forums.ni.com/t5/LabVIEW/GPS-PPS-counter-independent-from-FPGA-40MHz-Onboard-clock/td-p/2094...
Did you check it?
(2,931 Views)
