NI 9481 Scan mode
Hi
I am a beginner in the use of compact rio and labview,
I need to use the ni9481 like a switch (scan mode)
I have used the others analog input or output.
 Generally I drag and drop on my Vi the item but with this item when the program run
I recive this error code 1950679035, (see the  attached picture)
What I must to Do
(2,775 Views)
Hello kalla,
I've seen your screenshoot and I have note some strange message.
First of all, you have toset your PC and your cRIO with static IP address. Then, start with a new project and configure it. Remember that you cannot put this chassis in Scan Interface programming mode (see chassis properties in the Labview project).
You can configure Scan Interface for each module using Labview Help (Using the Scan Interface with Individual Modules)
Ciao!
______________________
Simone S.
Academic Field Engineer - Med Region
(2,748 Views)
