I have cRIO and NI-9751 driver module. I have downloaded the Powertrain Controls Device Drivers. I have few questions about this module.
- First of all, I had tried to trigger an injector with all possible combinations and i can trigger it but the oscilloscope shown in the screen had no signal. It had only default signal and never changed. (I attached a photo about it.) If you have any solution for this problem I would be glad.
- I am using (NI 9751 (DI) - RevF5 - Calibrator - RT.vi) I want to trigger an injector with injector open time (ti): 2 ms and duration (T): 15 ms parameters. How can I achieve this signal form with ‘NI 9751 (DI) - RevF5 - Calibrator - RT.vi’ ?
- And also I want to make some developments on ‘NI 9751 (DI) - RevF5 - Calibrator - RT.vi' and ‘NI 9751 (DI) - RevF5 - Calibrator - FPGA.vi’ but core code has been locked by NI. Is it possible to make some changes on it ?
I would appreciated if you could help me. Thank you in advance
