NI-9862 module not working properly with hybrid mode
I have cRio 9035. And I'm using NI 9862 C module to read CAN messages from car CAN bus. Also, I have other C modules to read/write analog signals. So, I need to have FPGA code for that purpose.
However, NI 9862 module only works in scan mode. As a workaround, I'm using hybrid mode, in which I added the CAN module under "Real-Time Scan Resources" in LabView project (snapshot attached). That worked fine, and I manged to create nxSession (using XNET drivers) from cpp code. However, the CAN module seems to be not responding and I'm unable to see any CAN messages coming thru it.
I tried to deploy cRio into scan mode, and I was able to see CAN messages correctly. But using this mode will block me from accessing other modules thru FPGA code.
Any suggestions?
Mohammed
(2,759 Views)
What do you mean by creating nxSession (using XNET drivers) from cpp code? Are you using the NI-XNET API for LabVIEW Real-Time? I do not see a LabVIEW Real-Time VI added under your cRIO-9035 in the image you attached.
Did you follow the steps described in this Knowledge Base article to configure your cRIO in Hybrid Mode?
Gustave
(2,727 Views)
We have a VI (carControl) under FPGA target that does the interfacing between analog modules and variables used in RT c++ code. There is no logic related to the CAN module in that VI.
The CAN module is initialized and used thru RT c++ code. Here's the code snippet for initializing an XNET session with the CAN module:
#include <nixnet.h>
nxStatus_t l_Status  = nxCreateSession(l_pSelectedDatabase, l_pSelectedCluster,
l_pSelectedFrameList, l_pSelectedInterface, nxMode_FrameInStream,
&m_SessionRef);
Am I missing anything in LV part?
Mohammed
(2,712 Views)
