NI-9871 Not Showing Up in Project Explorer
I'm testing out LV2023 Q1 32bit for compatibility with Windows11 and current designs at work.
I installed LV2023 Q1 32bit with CompactRIO 2023 Q1.
When I try to add NI-9871 manually to my project under Real-Time Resources, NI-9871 is not listed under New C Series Module.
I went to "Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, and EtherCAT" web page to check the module for compatibility, It looks like it good from CompactRIO 15.0.
All other C Series Modules are able to be selected.
I upgraded to CompactRIO to 2023 Q3 with the same results.
Am I missing something?
Thanks.
Willie
NI Hardware and Software Operating System Compatibility
(1,032 Views)
Added Note.
This work well in Windows 10 LV-2019 SP1.
(1,030 Views)
