NI ADSL Parametric Test Platform
Hi all,
I have downloaded NI ADSL Parametric Test code from NIs web site. When i try to run the code it asks for the "Limit Testing for cluster.vi" under mamon.llb. I have checked my NI directory and found "mamon.llb" but not "Limit Testing for cluster.vi" inside? Any help/comments? I have LV7.0 already installed,WinXP
Regards.
(2,879 Views)
Hi tmm,
For this particular example, the Limit Testing for cluster.vi has been renamed to Limit Testing.vi. You can find this vi in mamon.llb. What you must do is ignore the subvi when loading, and then trace back to this vi. You will see it will have a ? in place of its icon, with broken lines around it. Go ahead and replace the ? with the Limit Testing.vi, and make sure it is wired. You also may have to relink some subvis. To do this, locate the subvis in question, right click on them, and select "relink to subvi". This should fix all of your problems!
Jeremy L.
Jeremy L.
(2,879 Views)
