NI ARM MCB 2300 debug error
Dear All,
I am currently working on the MCB2300 board using the NI ARM embedded module. I was programming the board for a DC motor control. While I was running through several iteration, I landed up in the following error and I am not able to program the board since then.
The error was:
[3:01:25 PM] Status: Error
No JTAG Devices Found
Error: Target DLL has been cancelled
Debugger aborted !
Detail: [UVSC_DBG_ENTER, MSG: 0x2000, STATUS: 0x1] (1)
Status: Run failed.
[3:01:25 PM] Status: ErrorNo JTAG Devices FoundError: Target DLL has been cancelledDebugger aborted !
Detail: [UVSC_DBG_ENTER, MSG: 0x2000, STATUS: 0x1] (1)Status: Run failed.
I am sure someone has faced this problem. How do I resolve this issue?
Sincerely,
Sai
(3,057 Views)
Hi Sai,
It sounds like it is not finding your ULINK2. Can you see the ULINK2 in device manager?  Is it showing up correctly?  If it is not I would suggest restarting your computer.  If it is showing up correctly I would suggest trying one of the example programs.
Please let me know the results.
Justin Parker
Product Support Engineer
(3,035 Views)
