NI Batch Installer Builder to install in separate Program Files folders
I want to install on a deployment machine the NI-VISA in the National Instruments subfolder and my Application in a separate subfolder inside the Program Files folder using NI Batch Installer Builder.
I have tried the application with two installers in the bundle but unfortunately both tools (my LV. app and NI-VISA) are placed in the National Instruments subfolder which don't meet the project requirements.
If my requirement can't be covered by NI Batch Installer is there such an application which allows to split installations in different subfolders?
P.S. As LV Builder Install doesn't allow to add VISA Test Panel I am forced to use bundle install of Full VISA on the deployment machine (another project requirement is to have VISA Test Panel on deployment machine NI-MAX )
(2,176 Views)
If I understood correctly, I believe there's no need to use the NI Batch Installer Builder. You can use the Build Specification Feature on the LabView Application builder. From there you can select any additional installers you may need.
Here is a guide for Using the Build Specification Feature in the LabVIEW Application Builder, and  for Creating Sub-Folders for Files When Building a LabVIEW Application.
Hope it helps out!
(2,049 Views)
