NI-CAN BUS MONITOR
I am using the NI-CAN bus monitor in measurement and automation explorer. I would like to observe all frames on the network. However, if multiple frames use the same Arb. ID it only displays the last frame received. Is there a setting that will enable me to see every CAN frame as they appear on the network. I know that you can use the ID logger window to display all frames of a particular ID but I would like to be able to see every frame. Is there a way to do this?
Kyle
(3,140 Views)
Hi Kyle,
Aside from using the ID logger, you could stream all the CAN data to a file (Options » Streaming Setup).
Would that do the trick?
-B2k
(3,116 Views)
