NI-DAQ 6.6 and Test Panels
I installed NI-DAQ 6.6 with my PCI-7030/6040E RT boards.
But the test panels icon is greyed out, meaning I cannot do a quick check.
Is there a seperate program to install to activate the Test Panel?
Thanks.
(6,842 Views)
i don't think 6.6 is 'finished' it trashed all my setting for a daq-500 and i had to go back to 6.1 to finally get
it to work again.
if you haven't DON'T install 6.6
On 10 Nov 1999 19:25:39 -0600, "leufm"
selected comp.lang.labview as the chosen ones to read:
You said->"
You said->"Hi,
You said->"I installed NI-DAQ 6.6 with my PCI-7030/6040E RT boards.
You said->"But the test panels icon is greyed out, meaning I cannot do a quick check.
You said->"
You said->"Is there a seperate program to install to activate the Test Panel?
You said->"
You said->"Thanks.
NOSPAMithinkergoiam@hotmail.com
Remove NOSPAM and convert caps to reply.
For the spambots
webmaster@localhost abuse@localhost postmaster@localhost
uce@ft
c.gov wkennard@fcc.gov sness@fcc.gov
hfurchtg@fcc.gov mpowell@fcc.gov gtristan@fcc.gov
president@whitehouse.gov vice.president@whitehouse.gov
(6,842 Views)
I must admit, I'm a bit curious by what you mean with "...it trashed all my
setting for a daq-500". There are only 2 settings you can choose for this
card: Device number, and accessory. The rest of the card's information is
held by the operating system... such as base address, IRQ, slot, etc. NI-DAQ
simply reads this info from the OS.
Was the problem, perhaps with any custom Channel Wizard channels? With NI-DAQ
6.5.x (which came out about a year ago), we introduced the Measurement &
Automation Explorer. This utility integrates the former Channel Wizard from
LabVIEW, into its own shell. These channels are referred to in M&A Explorer
as "Virtual Channels". The upgrade path should have been seemless.
NI-DAQ 6.6, was rigorously tested before it was released and is quite possibly
the most stable version I have ever seen. I apologize for the fact that
you have seen difficulty using NI-DAQ, however your efforts would have been
much better spent working with our support team to find a fix to your problem.
If you have not already, please contact them at: support@ni.com
Best Regards,
DAQ Product Support Engineer
and i had to
>go back to 6.1 to finally get >it to work again.>>if you haven't DON'T install
6.6>>>On 10 Nov 1999 19:25:39 -0600, "leufm" >selected
comp.lang.labview as the chosen ones to read:>>You said->">You said->"Hi,>You
said->"I installed NI-DAQ 6.6 with my PCI-7030/6040E RT boards.>You said->"But
the test panels icon is greyed out, meaning I cannot do a quick check.>You
said->">You said->"Is there a seperate program to install to activate the
Test Panel? >You said->">You said->"Thanks.>>-------------------------------->NOSPAMithinkergoiam@hotmail.com>Remove
NOSPAM and convert caps to reply.>For the spambots>webmaster@localhost abuse@localhost
postmaster@localhost>uce@ftc.gov wkennard@fcc.gov sness@fcc.gov >hfurchtg@fcc.gov
mpowell@fcc.gov gtristan@fcc.gov>president@whitehouse.gov vice.president@whitehouse.gov
(6,842 Views)
The test panels button should be greyed out for the 7030/6040E RT board, this
is the correct behavior. There is no path of communication between the host
computer and the DAQ daughter card with the present architecture. The best
way to test and verify the state of the RT DAQ device is to run one of the
LabVIEW DAQ examples and verify the results.
and i had to
s.>You said->"But
(6,842 Views)
