NI DAQ 6501
Hi, can i use NI Daq 6501 with only digital i/o to acquire 7v from rs 232,
then show the 7v value to my front panel????
if possible, please give some suggestion or vi that i can use as a reference.
thank you very much in advance.
any help is highly appreciated...
(2,493 Views)
Hi 1der,
No.
Use a serial port for serial communication. Or use a DAQ device capable of analogue input to read voltage signals...
(2,461 Views)
http://www.ni.com/pdf/manuals/375268c.pdf p2: Input high voltage 2.0 V minimum, 5.8 V maximum So, your 7V can works unstable (and can be dangerous for DAQ) If you want to try, see examples fot digital continuous unput.
(2,459 Views)
