NI DAQ with 48 DIO
Hello everyone,
I am going to use NI PCIe-6323 for my system. The module has 48 DIOs. I am going to have 8 DI (port 1 8 channels) and 40 DO (port 0 32 channels + port 2 8 channels).
My concerns are about using 40 DO channels in the LabVIEW.
The best option from my architecture point of view to use 2 separate DO sessions (DAQ 2 Sessions.png).
But as far as I remember DAQ doesn't allow 2 sessions for the same type of channels.
Though I have tried with simulated device and there was no error.
The other option is to write with 1D boolean array. It is not be the best option but I have more confidence that it should work (DAQ 1 Session 40 channels.png).
Please comment or feel free to offer better approach if had any experience.
Thanks in advance.
(1,349 Views)
Accepted by topic author LevonSynvue
The limitation is only applicable if you use hardware-timed tasks with sample clock timing. See Number of Parallel DAQmx Tasks on NI Multifunction Devices
Your attached images show on-demand software-timed tasks. Whether you use one or multiple tasks for the DO lines makes no difference.
https://tmesystems.net/
(1,346 Views)
