NI DAQ
Hey there,
I wanna generate a signal in labview and want to simply display it on oscilloscope , by usinf DAQ USB 6009 , but i 'm unable to do so , i 'm also attching a copy of my created file . I'll appretiate if any one can help me out.Thank you
(2,784 Views)
The USB6009 does not produce sinewaves on it's analog out, just 0-5 volt DC levels and pulses.
Analog Output
Channels 2
Resolution 12 bits
Max Voltage 5 V
Maximum Voltage Range 0 V - 5 V
=== Engineer Ambiguously ===
(2,782 Views)
I can't look at your VI right now, but as it has been discussed before, the only thing you can do is write the waveform array one point at a time. This wil be at no higher frequency than listed in the specs and with considerable jitter.
(2,756 Views)
