‎03-05-2015 08:25 AM
I try to install an application using labview 2014 with an acquisition device NI USB-6251 on a Windows 7 platform brand new embedded.
The problem is it seems the installer refuses to install DAQmx 14.2 on this machine, I just get the following messages:
(See the images below)
Whenever I confirm Insatallation to continue to the end.
When the PC is restarted, the NI USB-6251 device is not recognized either by windows or by MAX. (Not valid drivers)
I transferred the driver manually (nixsrkw.sys) of a PC that works with the device in the path I indicates the installer plug and play windows (Windows / system32 / drivers), without success! (No valid driver)
I tried several installer configuration, nothing happens, I have to wonder if NI DAQmx14.2 is compatible with Windows 7 Embedded ...
Thank you for helping me a bit if you have already encountered this kind of problem, I do not understand what blocks the installation of the USB driver.
Sorry for my poor English 🙂
Greetings to all.
Lionel
‎03-06-2015 03:33 AM
Hi Lio_CH!
You need administrator rights to succesfully install the drivers. Did you run the DAQmx 14.2 as administrator? I'm not acquainted with windows 7 embedded. But in win7 you right click the .exe and choose run as administrator. Did you try this?
Best
Miello
‎03-06-2015 04:39 AM
‎03-06-2015 07:36 AM
‎10-09-2015 11:03 AM
Hi ,
I have a similar problem. Can you tell me if you were able to resolve the problem.
Ram
‎11-30-2016 07:42 AM
Yes, i was always administrator on this machine, that's not the problem...
‎11-30-2016 07:43 AM
No, I have not found a solution, yet after long sought and tried different solutions.
I ended up buying a Windows 7 pro license and installing it on this touchpad, the NI DAQMx libraries now work with this environment ...
