NI DAQmx 9.2.1 driver installation
I have installed Labview 8.6 on my PC running on windows 7 32 bits. My PC hangs halfway through the installation of NI DAQmx 9.2.1 driver software. May I know what happened?
(2,678 Views)
I experienced the same thing when I reinstalled LabVIEW. I cancelled it and restarted the installation. The first time, I was doing alot on the computer while it was installing the driver. The last time, I didn't even move the mouse heheSmiley Very Happy And it worked
I also disconnected all the DAQ equipment I had.
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
(2,677 Views)
Hi Even,
I am wondering if that is compatibility issue between labview 8.6 and NI DAQmx 9.2.1 or due to the windows 7 32 bit hat i am using. I installed labview 8.6 via the setup.exe found inside labview 8.6 distribution folder. Did the installation of NI DAQmx 9.2.1 hang because of some missing files?
 THanks for your reply.
KT
(2,669 Views)
Hi!
I first ran the Dvd's for installing LabVIEW 2010. During the installation I got prompted for the driver DVD. When the driver setup had reached around 70% it hanged. So I cancelled it and ran the setup from the driver DVD itself.
i was installing it on a windows 7 32-bit system.
Even
Topro AS
Norway
(2,655 Views)
