NI-DAQmx Base 3.2
hi,
As far as I know, NI-DAQmx Base 3.2 can create channel for voltage and thermocouple. How may I create channel for acceleration and pressure?
Thank You for helping
(3,056 Views)
You create it the same way, you create the other tasks you mentioned.
Christian
(3,054 Views)
Thank you for your reply.
In DAQmx create channel drop-down menu, we have acceleration and pressure. But, in DAQmxBase create channel drop-down menu, we do not have acceleration and pressure. That's the reason why I doubt we cannot use DAQmxBase for acceleraion and pressure.
(3,050 Views)
Hey,
I don't have DAQmx Base installed to check this, but if there is no such entry, then you can just read the voltage the sensor provides and do the necessary scaling or calulations after you read the voltage data.
If possible, you should use DAQmx.
Christian
(3,047 Views)
