NI DAQmx Configuration
I'm using a NI DAQmx.Normally the configuration would be done manually for DAQ.Rather
based on the user input i need to configure the channels programatically.Suppose user input is (N),
then N channels needs to be configuired.Could anyone please help me out solving this? Thanks in advance.
(2,768 Views)
You can use the DAQmx Create Virtual Channel vi to add Virtual channels to a task. In you case, you want to programmatically control how many times that vi is called. If you call it twice, you would have 2 channels in your task, 3 times -> three channels. The easiest way would be to put this VI in a FOR loop in LabVIEW. The User input can be tied to the N (loop count) of the FOR loop.
Hope this helps & let me know if you need further clarification,
Anuj d.
(2,755 Views)
