NI-DAQmx Driver Support for LabVIEW 2025 is missing
I am seeing the NI-DAQmx Driver support for LabVIEW 2025 is missing while I can see both NI-DAQmx and NI-DAQmx Runtime 2025 Q1 Patch 1 is installed on my computer according to the license manger. What could be the problems and solution?
(2,448 Views)
Starting with LabVIEW 2022Q3 release, select NI drivers and toolkits will become version-independent from LabVIEW release. This will allow users to upgrade their LabVIEW version without having to also update their NI addons. Reference: Extending Compatibility Between LabVIEW and NI Drivers with Addon Support
You will see only one NI-DAQmx Support for LabVIEW without any version suffix to it.
https://tmesystems.net/
(2,411 Views)
