NI-DAQmx Driver support for LabVIEW 2017 is missing
I have developed a very simple code to acquire data from a NI DAQ in LabView and it works just fine on my desktop. but whenever I try to run it on my laptop I get the error in the title:
what is the issue and how can I solve it?
(13,194 Views)
did you install the DAQ drivers after labview on your laptop.  DAQmx is seperate install from Labview.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(13,167 Views)
I actually installed it in advance. and now when I try to install it again I get this blue screen error!
(13,159 Views)
Accepted by topic author foadsf
I think I have figure the issue out. I yet to test the code with the DAQ connected, but at least I don't get the error I get before.
So basically what is wrong is when you install NI-DAQmx drivers in advance to LabView and you do not locate the drivers while installing, you get this error. and to solve you simply need to install the drivers again. just go to this page, download and install.
(13,150 Views)
