NI DAQmx Express VI
hi All,
I'm using LabVIEW 7, I was trying to use the NI-DAQmax Express VI based on the NI tutorial. but the NI-DAQmax Express VI does not appear on my Functions palette. neither on the INPUT sub palette or inside the DAQmx sub palette which also does not appear on my Advanced functions palette.
there's a was to install above mentioned VI's or is matter of the LV version?????
(3,664 Views)
Hi Dukmarivan!
This is most likely a problem with the driver installation. To be able to check the Daqmx VI's is necesary that you install correctly the driver and add support for the particular version of labview you are going to use, in this case Labview 7. The following link takes you to the driver page of daqmx, please download it and proceed to install it, reboot your system and after that you should be able to find the VI's. Please make sure you add support for the version 7 of labview.
http://joule.ni.com/nidu/cds/fn/p/sb/navsRel/lang/es?q=daqmx
Have a great day!! 🙂
Oswald Branford
(3,646 Views)
hi Oswald,
I will install the instruments drivers and hopefully that corrects the problem.
thanks for your help.
MG.
(3,613 Views)
