NI-DAQmx Icon Missing in Labview
I had to reinstall LabView and now my NI-DAQmx icon is missing (actually a bunch of DAQmx related icons are missing). I can view the NI-DAQmx icon showing a question mark when go to Tools-Advanced-Edit Palette Set and select Measurement I/O. The path it reports is C:/Program Files (x86)/National Instruments/LabVIEW 2012/menus/Categories/Measurement/daqmx.mnu. As you can see I have LabView 2012 installed (version 12). In NI MAX I can see NI-DAQmx ADE Support 9.5.1,  NI-DAQmx Device Driver 17.1.1,  NI-DAQmx MAX Configuration 9.5.1. Is it because the device driver rev is 17.1.1? Also Measurement Automation Explorer shows Rev 5.3.0f0.
(2,900 Views)
Accepted by topic author duncanmcdonald
Found the solution. The NI-DAQmx rev was too low. Updated to 15.5 from 9.5.1 and everything works now.
(2,882 Views)
