04-23-2026 12:45 PM
I’m new to LabVIEW and working on a data logging application that acquires multiple strain channels at 50 kHz, and multiple thermocouple channels at 10 Hz.
I created separate DAQmx tasks in NI MAX for each sensor type (I zero/calibrate my sensors here), and I’m using continuous sampling for both. In LabVIEW, I configure each task using DAQmx Timing VIs, where I set the sample rate (50 kHz and 10 Hz respectively).
Problem:
The thermocouple data appears to lag significantly.
Questions:
Any guidance on architecture or DAQmx best practices would be greatly appreciated.
Thanks!
04-23-2026 01:17 PM
Please let us know what equipment you are using. Some of the daq cards for thermocouples is really slow.
04-23-2026 01:36 PM
Yes, I have an NI 9178 8 slot chassis.
For strain I use 5x NI 9237 DAQ's
For thermo I use 3x NI 9211 DAQ's
04-26-2026 08:31 PM
1. Does the DAQmx Timing configuration in LabVIEW override NI MAX settings, or could there be a conflict?
Think data flow. Whichever come later will override the previous one.
2. Is using Samples = Duration × Rate for continuous sampling causing large buffer sizes and delayed reads?
Since you are using -1 in the DAQmx Read VI, which only reads when all data has arrived, so yes.
3. If I need the data to be in sync for post-processing, what is the best approach for synchronization?
Use channel expansion to combine multiple channels into a single task. The slower thermocouple reading will have duplicated data points on the faster strain reading.
04-28-2026 07:27 AM
Thank you very much.
In regard to channel expansion, as you can see I am using the data output from the DAQmx Read VI to generate channel names for my tdms file. With both task types being combined, is there a better alternative method for keeping track of channel names.
Each pair of bi-axial strain gauges has a thermocouple associated with them, so the numbering is important.
