09-16-2008 11:28 AM
Hello
I am currently migrating a Labview application from a laptop to a pc for my company, and I am reinstalling all the NI-softwares.
Unfortunately, I came across the following problem:
I first installed DAQmx 8.5 after Labview 8.2.1, and then made an update to DAQmx 8.7 (with the same download used for the laptop, which works fine).
I am using a DAQPad 6015/6016 and 3 USB carriers, all connected to the PC with a hub.
When I connect them, the NI-DAQmx directory does not appear in MAX. Moreover, I have noticed that MAX has not listed DAQmx as an installed component, but Windows XP does.
I have already tried to repair MAX´s installation, or to connect the usb-devices one by one.
I must say it is not the first time I do not find the NI-DAQmx directory in MAX: I have previously tried to install the system on Windows 2000, it worked with DAQmx8.5, but not with DAQmx8.7 (!) (even if I tried many times to reinstall it...) After the update, the directory was always erased in MAX...
So I decided to move to XP, because the Laptop is running with XP, hoping it would be better... but it didn t...![]()
I thank you in advance for your help!
09-18-2008 11:04 AM - edited 09-18-2008 11:14 AM
Hello Sharter,
the DAQmx-entry appears in MAX only if there is a NI DAQ-device connected with your PC or if you have a simulated DAQ-device in MAX.
So, first check if the DAQmx driver is installed: Open MAX - there should be an entry NI-DAQmx XXXX under 'Software'.
Now
you can test if it is possible to create a simulated DAQmx-device:
devices and interfaces -> rightclick -> new -> NI-DAQmx
simulated device. Choose a M-series, e.g. a NI PCI-6221 , because your
DAQpad can't be simulated.
If this works take a look in the Windows device-manager: (For this test connect the DAQPad with a short USB-cable to the PC - without hub.)
When the DAQpad is connected and the driver is working properly, there should be an entry 'Data Acquisition Devices' -> DAQPad-6015 and the green Ready-LED at the front of the DAQpad should light steadily.
If
not there is a problem with the driver: Go to the device which seems to
be the DAQpad (maybe there is a yellow question mark) and go to
properties -> update driver.
Sometime it happens, that there is an old device-entry
which blocks the driver. So check if there are hidden devices (under
view). If yes remove them.
I hope this will solve your problem.
With best regards,
Ralf N.
Note: At last you should deletethe the simulated 6221 in MAX.
09-18-2008 11:18 AM - edited 09-18-2008 11:23 AM
Here another troubleshooting-tutorial:
The following steps cover most of the common issues with a DAQPad not showing up in MAX:
09-23-2008 11:37 AM
Hello Ralf
Thank you for your help and for the references... it is not always that easy to find the adapted documentation on the NI website
Because of a major bug caused by the USB devices, I decided to retry to update from 8.5 to 8.7.
I have began to check in MAX if my update of Labview was listed. As after the former attempts, it was not the case.
So I decided to migrate to DAQmx 8.8, and, surprise, this time it was working properly !
I think I am going to keep this last version... Even if everything it contains is not that useful, at least it works, that the essential. I guess my version was corrupted, or maybe I did not have a compatible version of MAX.
Best regards
Sharter
09-23-2008 12:07 PM
Hello Sharter,
glad to hear that it works now.
I wish you the best of luck with your application.
Have a great day.
Ralf N.
