Showing results forĀ
Search instead forĀ
Did you mean:Ā
NI-DAQmx for LabView 2010 SP1
I am looking for NI-DAQmx installation package for LabView 2010 SP1 64 bit?
(4,596 Views)
Right now it looks like you are looking at the LabVIEW discussion forum.
What version of DAQmx are you trying to install?  I'm pretty sure there is just one set of drivers to handle both the 32-bit and 64-bit.
(4,593 Views)
I just downloaded NIDAQ975f1.exe and extracted it. When I ran it and changed the directory for it to install to 'C:\Program Files\National Instruments' it gave me an error message, see attached screen capture. This NIDAQmx is not for the 64 bit LabView application. I have the 64 bit LabView 2010 SP1 application and am looking for the 64 bit NI-DAQmx application.
(4,577 Views)
Don't change the install folder. There is no 64-bit version. You use your 32-bit version of LabVIEW with DAQmx.
(4,574 Views)
Even with the 64 bit LabView application?
(4,568 Views)
Accepted by topic author JackSC3
Yep.  Do not change the destination directory.  The drivers will add support for whatever version of LabVIEW you have installed starting with LabVIEW 2010.  This includes the 32-bit and 64-bit versions.
(4,551 Views)
That worked. Thank You.
(4,527 Views)
