NI-DAQmx scaling of Global Channel
I have created a Global Channel in Max that has custom scaling.  In LabVIEW I have bound an indicator to the Global Channel.  I have labview running and the values are being displayed in the indicator.
With LabVIEW running, if I change the scaling values in MAX, the values displayed in LabVIEW have not changed, they are still displaying the original scaling.  Is it possible to update scaling without shutting down my labview application?
(1,750 Views)
Yes it is possible if the scaling values are changed from your application but not from MAX.
Yddet
(1,690 Views)
