NI DAQmx
I would like to know if it is possible to do a self calibration of the DAQmx with LabVIEW. I have the NI USB 6353.
Thank you
(3,595 Views)
Palette: DAQmx -Data acquisition -> DAQmx Advanced -> DAQmx Calibration -> DAQmx Self calibrate.vi
Technically you are not calibrating DAQmx, you are calibrating device using DAQmx driver, and calling self-calibration function from LabVIEW.
(3,569 Views)
Ok, thank you
(3,531 Views)
