NI DCPower 17.0
I am trying to set a sequence of current values with the PXIe-4139 while measuring the exact current and voltage values for each step of the sequence.
I do not have any experience with the DCPower driver so far.
Correct me if I´m wrong:
I am able to set the points for the sequence with the niDCPower Set Sequence.vi after initializing with the DCPower Initialize with Channels.vi. Then I have to go into the committed state with the Commit.vi.
For applying the sequence I use Initiate.vi so the sequence is set by the PXIe-4139.
How is it possible (if it is possible) to trigger a measurement of the actual current and voltage for each step of the sequence?
Thanks in advance.
(2,698 Views)
Hi there,
did you have a look at the examples delivered with LabVIEW? There is an example NI-DCPower: Advanced Sequence Changing Output Function.vi which does pretty much what you try to accomplish as far as I understand.
It is not triggered, but you can combine it with one. You need the Sequence Advanced Trigger.
Hope I could help you
Heinz
(2,617 Views)
