NI DIDS module use for controlling IC Engine
Dear all
I wish to clarify some doubts in NI DIDS module. I am Ph.D reserch scholar from IC Engine Lab, IIT Madras. We working on the development of a GDI engine. We are using NI DIDS system as engine controller. I have following doubts.
1. How to use active high and active low to give engine synchronous TTL signal?
2. Like end of injection timing in DI module is it possible to mention end of TTL signal timing in active high mode?
3. Where to mention active high signal duration in DIDS program? Are we suppose to give it in PFI module injector current and duration option?
4. Our TDC signal is coming 164 degree BTDC how we can offset this to the actual TDC signal?
I am from India. Unfortunately we are not getting good support. SO kindly help me out.
Message 1 of 1
(2,248 Views)
