NI DMM 4065
(3,734 Views)
(3,730 Views)
NaN means overrange. How are the express vis configured? we cant tell from a picture! However if you press Ctrl+A (Select all) then go to Menu>>Edit>>Create VI Snippet from selection. you can post the *.png that creates and we can work with that.
(3,702 Views)
Things Not To Do
  • If you edit your post, don't remove information.  Some users choose to edit their posts after they get the answer they were looking for.  And they will completely remove their original question and replace it with nothing or "Thanks".  This creates a thread where the first post just says "Thanks" and then there are several replies answering a question that is no longer there.  The community exists to help others with the same question find help, editing your question or posts this way helps no one.
https://decibel.ni.com/content/docs/DOC-40451
(3,643 Views)
