NI Device Drivers Aug 2015
C:\National Instruments Downloads\NI Device Drivers\Aug15\Install info.docx will not attatch.... 😞
Message 11 of 25
(2,451 Views)
I believe that's a blocked extension.  Upload the images themselves or try changing the extension to fool the filter.
Message 12 of 25
(2,445 Views)
I also tried a zip. LOL.. what a pain!!
Message 13 of 25
(2,438 Views)
See attached and rename to .docx
Message 14 of 25
(2,436 Views)
Trying firefox...
Message 15 of 25
(2,434 Views)
Try being sure that the 3 diffferent .exe's extract to 3 different folders.  That sounds like how Matthew's installed, while you say yours is all going into one.
I'm wondering if the NIdist.ID is being overwritten.  Each DVD should have it's own, but with all in one folder, you only have the one.  And your install stalls when it can't find the .id file for the next DVD.
Message 16 of 25
(2,420 Views)
Your entire directory structure does not make sense.  DId you change the default unzip path?
I ended up with a DCD-Aug15-1 and DCD-Aug15-2 directory in the Aug15 directory.  In DCD-Aug15-1, I only have a Documents, LicenseAgreements, Products, and SupportFiles subdirectories with the same files you have.
In DCD-Aug15-2, I have Products and SupporFiles subdirectories and only an nidist.id file.
It looks like you are unzipping both packages into the same directory instead of individual directories and the packages are overwriting files.
Message 17 of 25
(2,417 Views)
I have extracted them to different folders a few times already. Same results. But I'll try it again.... freaking again!!! Wow.... Thanks for the help though guys...
Message 18 of 25
(2,413 Views)
 I did was launch the EXE and not change anything.  I let it unzip the files to the diretcory it wanted to.
Message 19 of 25
(2,403 Views)
hold on ... trying it now.
Message 20 of 25
(2,397 Views)
