NI Digital Pattern Editor Save Capture for Comparison
Is it possible to save the data that I just captured (potentially in a register), then capture again and compare the two? I want to see if a new measurement matches the last measurement. I can easily do this afterwards in Labview by capturing all the data, but I was wondering if I could utilize the match function.
-I want to take a measurement (capture), then take another measurement (capture) and check if they are the same.
Thanks!
(1,766 Views)
Nope, not from the Digital Pattern Editor. You can do it manually or using LabVIEW / drivers
Santhosh
Soliton Technologies
(1,757 Views)
