NI-ELVIS Series II - Can we Change the frequency range of "impedance analyzer"
NI ELVIS II kit, impedance analyzer function has following frequency range specification:
Impedance Analyzer
Measurement frequency range .......... 1 Hz to 35 kHz
Whereas Bode Analyzer has a Frequency range in NI ELVIS II .................1 Hz to 200 kHz.
Is it possible to change the frequency range of the Impedance analyzer? I have to measure impedance in the range of 70kHz-80kHz.
If yes! how I can do that? Can I make my own Labview Program?
(1,854 Views)
You can try to use NI ELVISmx Express VIs.
For that, you need to install NI-ELVISmx drivers.
Best regards.
(1,780 Views)
