NI Elvis III Board
Hello, I am using in the lab a 32-bit NI Elvis III data acquisition board, and the 32-bit LabVIEW is constantly crashing due to its small memory (i have a lot of data to be stored at once). So is there any way I can use the 64-bit Labview on this DAQ board? Thank you!
(2,515 Views)
Read the specs of the Elvis III.  It runs a 32-bit OS, NI Linux Real-Time (32-bit).  Furthermore, it has only 0.5 GB of volatile memory, which is undoubtedly the cause of your problems.
Because the Elvis III runs its own version of LabVIEW RT, you can "pair" it with a PC running LabVIEW (even 32-bit!) and gain a very powerful system -- the Elvis doing data acquisition and control at an impressive sampling rate (approaching 1 MHz) and streaming the data at TCP/IP speeds to a host PC running LabVIEW on a 64-bit OS.  Even then, unless you need to work with "all of the data all at once" (as opposed to, say, streaming it to disk and doing off-line processing or simultaneously monitoring and displaying), you probably don't need 64-bit LabVIEW.
Of course, you'll need to be reasonably proficient in LabVIEW development (perhaps a skill set sufficient to pass a CLD exam) to tackle LabVIEW RT ...
Bob Schor
(2,500 Views)
I forgot to mention that I have a sampling rate n > 2.4 MHz. Im trying to get rid of unnecessary data through the process, but still I need more memory.
(2,496 Views)
Then you probably need different hardware.  The following are from Elvis III Specs on the Web (you might have a "more powerful" model, I suppose ...).
Memory
Nonvolatile
1 GB
Volatile
DDR3
512 MB
Clock frequency
533 MHz
Data bus width
16 bits
Analog Input
Number of banks
2, capable of independent operation
Number of channels per bank
8 single-ended or 4 differential
ADC resolution
16 bits
Input range
±10 V, ±5 V, ±2 V, ±1 V
Maximum sampling rate (single channel)
1 MS/s
Large signal bandwidth (-3 dB)
>500 kHz
Bob Schor
(2,491 Views)
